Disables BOOTPRelay v6. This can be done across the VR or on a per VLAN basis.
| bootprelay | BOOTP Relay service. |
| IPv4 | DHCPv4 BOOTP Relay service. |
| IPv6 | DHCPv6 BOOTP Relay service. |
| vlan_name | Specifies the VLAN name |
| vr_name | Specifies the vrtual router name. |
| all | Disables all VLANs. |
N/A.
Use this command to disable BOOTP Relay across the VR or on a per VLAN basis.
The following command displays IPv6 bootprelay information:
* switch # show bootprelay ipv6
BOOTP Relay: DHCPv6 BOOTP Relay enabled on virtual router "VR-Default"
Include Secondary : Disabled
    BOOTP Relay Servers :2001::1
                         3001::1
                         4001::1
VLAN "Default"         :
    BOOTP Relay        : Enabled
    Interface ID       : 3999 (Default)
    Remote ID          : 00:04:96:52:08:76 (Default)
    Prefix Snooping    : Disabled
VLAN "v1"              :
    Interface ID       : Interface-Sring1
    Remote ID          :
* switch #
    This command was first available in ExtremeXOS 15.5.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
